87 Mustang 5.0 problems
Old Sep 28, 2008 | 10:52 PM
fuelslut2483's Avatar
fuelslut2483
Default 87 Mustang 5.0 problems
Im having problems with my 5.0 HO engine in my Mustang. When I crank the car, i hear a loud vacuum leak behind the driver side dash. As I accelerate harder, the vacuum leak seems to get a lot quieter. If I accelerate too hard, the engine kicks and sputters a little. I hear that alot of cars have a vacuum line that runs from the distributor, are the 5.0's the same way? I would check myself but its a pain to open my hood and get it back closed due to hood flying up at 65 MPH and busting windshield and bending hood. Please reply to this VIA Private message (P.M)
Old Sep 30, 2008 | 12:04 AM
Blckstng93's Avatar
Blckstng93
I hate PM, so im posting here.
Forget the distributor if its the stock piece, they didnt have a vacuum line. Check the vac lines under the hood near the brake booster. There are a few lines back there, check those for leaks. Have a buddy crank the engine as you listen up front. Not sure if this applies, but do you have power brakes? The booster works on vacuum, so maybe its leaking.
Youre probably going to have to open the hood to find the problem.
Old Sep 30, 2008 | 09:23 AM
fuelslut2483
haha, ok. Yeah, the car has power brakes. There's something making it sputter at higher RPMS, im going to be putting in new plugs this afternoon sometime. I appreciate your reply.
Old Oct 1, 2008 | 08:22 PM
RUDEDOG.357's Avatar
RUDEDOG.357
I believe that some fords use a vacuum switch on the brake pedal for cruise disconnect. ck the hoses under the dash.
FD725
Aug 23, 2015 06:43 AM
MusBBad95
Aug 17, 2015 09:39 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
05slpGT
Aug 12, 2015 02:32 PM
daytooday
Aug 11, 2015 09:22 AM
