Fuse #13 Blows
Old Oct 21, 2008 | 12:14 AM
gt350dad's Avatar
gt350dad
Default Fuse #13 Blows
I have a 1984 20th Ann Mustang 5.0. And the dash lights don't work. I have found that fuse #13 blows every time I pull the headlight dimmer switch. Either with a 5amp 10amp or 15amp. When I put a 30 amp in.... The lights do show up but then after like 5 seconds fuse #4 will blow(20amp). Both #4 and #13 power the instrument cluster. What would cause this to happen. And I do have an aftermarket radio in if that matters. Other than that everything is stock.
Old Oct 21, 2008 | 01:11 AM
Stepman's Avatar
Stepman
Well, not being able to "see" it, I assume that the stereo works? If so, I would look for a short possibly in the taillights?
Old Oct 21, 2008 | 07:44 AM
forcefeed's Avatar
forcefeed
you need to look at wiring diagram and try and determine the most logical place to start, i don't think you would have a n issue in the taillight circuit, it will be on a different fuse than the dash lights, i would look for things like the obvious is there any after market equipment tied into that circuit, radio lights, gauges and the like.................ps the last thing you want to do is put in a bigger fuse!!
Old Oct 21, 2008 | 08:34 AM
halocorn's Avatar
halocorn
yeah the fuse was only to test something for a quick couple seconds.
by the way i'm gt350dad's son and its my car.
Old Oct 21, 2008 | 07:56 PM
forcefeed's Avatar
forcefeed
i would suggest using a 15a cycling circuit breaker if you are going to do any testing
Old Oct 25, 2008 | 10:18 AM
halocorn's Avatar
halocorn
Found the Problem.. The person that hooked up the radio I guess decided to wire fuse #13 to the radio's ground. So I just cut it and put electrical tape on the ends.
Old Oct 25, 2008 | 11:16 AM
67mustang302's Avatar
67mustang302
Blowing fuses is usually a result of either electrical shorts, or excessive voltage/current in the system. That's what the fuse is for after all, to prevent the system from overheating and starting an electrical fire.
jwog666
Dec 27, 2021 08:09 PM
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sixer4Life
Sep 29, 2015 07:03 PM
cbird1177711
Sep 2, 2015 04:12 PM
