98 mustang doesnt turn over
so i recently had some wires messed up under the steering column and put them back together and now i press the clutch and try to start it and doesnt crank.I checked the fuel pump reset and its good and i also checked the clutch sensor thing and thats good any suggestions?the lights work the radio works has a brand new battery
98 mustang gt 5 speed
Okay, well we will start off with the basics. What wires exactly were messed up? Were they down near your feet, in the steering column, where? Also, define "messed up" does that mean cut, frayed, yanked out? Most likely it is something to do with that wiring. How did you put them back together? Did you use wire nuts or crimp connectors? I really would put my money on the fact that the wiring is still messed up.
Most likely there may have been a short in the system, whenever you or someone messes with wires like that, you run the risk of causing a short. Also, check all your fuses, make sure none are blown. Truthfully, wire nuts is not the best option either, you really should use crimp connectors and then wrap it in heat shrink tape. Definitely would let the dealer look at that one or at the very least a qualified body shop. Call your ins. co. and ask who is on their program, they should give you a good reference.
Oct 1, 2015 09:11 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
