Sponsored by:
Sponsored by: DashLynx
Whats the difference between a.....
Old 11-15-2008, 05:38 PM
CyprusMustang
CyprusMustang's Avatar
Default Whats the difference between a.....
I have a 69 stang but the casting numbers on the engine say its from a 1974 ford falcon. The engine in both cases is a 302 but i want to know when ordering parts, do I order as a 69 stang 302?
For example i need the following: water pump ( next to the model number on the site im ordering, its says 302 but says 65/69 mustang
and with the exhaust manifolds, it says 302 but next to it reads 65/69
not sure what the **** to order???? anyone know???
CyprusMustang is offline
Old 11-15-2008, 06:22 PM
.boB
.boB's Avatar
Are you sure about that part number? I think the '74 falcon was only available in Australia.
Some parts will be unique to the engine - oil pan, intake manifold. But some parts will be unique to the chassis - water pump, exhaust manifolds. It all depends onm the part you need.
.boB is offline
Old 11-15-2008, 10:59 PM
CyprusMustang
Default CONFUSED
Yea i want to http://www.classicmustang.com/decoding_part_numbers.htm and with my engine number D4DE6030AA ....the D is 1970, the 4 is for 1974, the next D is for Ford Falcon and the E is for Engine. Dont know guys im confused. I need to order the following things and not sure which and what to order.....
1. Exhaust Manifolds
2. water pump
3. Gasket Set
4. Pulleys
please someone help!!!!!!!!!!!!!!!!
Old 11-15-2008, 11:22 PM
w8less
w8less's Avatar
most of the parts will fit it but like he said some parts will be unique to the chassis. not much changed throughout the years for the 302
w8less is offline
Old 11-16-2008, 11:41 AM
CyprusMustang
do you guys think the exhaust manifolds and the water pump are the same?
Old 11-16-2008, 01:10 PM
.boB
.boB's Avatar
Those parts will fit pretty much any 302 engine. But they are unique to the chassis. For example, some cars have the water pump inlet on the left, and some on the right.
For those parts, don't worry about the year of the block, pick the right ones for your chassis.
.boB is offline
Old 11-16-2008, 03:22 PM
CyprusMustang
Default ill take some photos
ill go take a shot or two of my engine and post it. then you guys can tell me what you think!
Dokilar
15
10-16-2015 08:13 PM
UrS4
09-30-2015 10:13 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: Whats the difference between a.....
