3.73
Old May 28, 2005 | 02:51 AM
Crazyfast50stang's Avatar
Crazyfast50stang
Default 3.73
Hey I might buy some 3.73 gears with 6k miles on them. for about 40 dollars. Is the milage to much? no chips or anything. Is it worth it? ALSO they are off of an explorer.
Old May 28, 2005 | 03:23 AM
Crazyfast50stang
Default RE: 3.73
[sm=feedback.gif]
Old May 28, 2005 | 04:28 AM
HAUS's Avatar
HAUS
Default RE: 3.73
if explorers use an 8.8 rear end then you can use them. if the gears are in good condition i say get them. 6k miles aint too bad.
Old May 28, 2005 | 11:01 AM
stanglx2002's Avatar
stanglx2002
Default RE: 3.73
6k isnt a lot of miles and if they will fit then get them
Old May 28, 2005 | 02:06 PM
Quik's Avatar
Quik
Default RE: 3.73
i thought explorers had a 31 spine carrier, also mileage isnt a factor in used gears its wear pattern
Old May 28, 2005 | 02:30 PM
C/Note's Avatar
C/Note
I ♥ Acer
Default RE: 3.73
THE GEARS will work ..the carrier wont ..ohs is right about the splines 28 / 31 ...
Old May 28, 2005 | 04:30 PM
92hatchLX's Avatar
92hatchLX
Default RE: 3.73
What year of exploders had the 3.73 gears??? I've seen about 20 different exploders in our local junkyard...
Old May 28, 2005 | 05:09 PM
tomabram's Avatar
tomabram
Default RE: 3.73
I would never buy used gears. $100 or so more to get new ones.
Old May 28, 2005 | 05:50 PM
Quik's Avatar
Quik
Default RE: 3.73
gears if installed right and lubed can last for thousands and thousands of miles. they just dont go bad. now if set up wrong then yes. you need to watch for wear thats it
Old May 28, 2005 | 09:30 PM
tomabram's Avatar
tomabram
Default RE: 3.73
ORIGINAL: ohsoquik02
Not always. I sheared 7 teeth off a ring gear years ago, and they were set up and lubed right. So YES, they can fail. Just like ANY moving part.
uberstang1
Dec 7, 2017 07:10 AM
JoePSL
Aug 24, 2016 02:50 PM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
Darien
Sep 16, 2015 09:30 AM
gus_vb
Aug 29, 2015 11:35 PM
