Signal Flasher Problem
Old Dec 17, 2008 | 01:45 PM
jbcorder's Avatar
jbcorder
Default Signal Flasher Problem
2002 Mustang - left side signal flasher works fine, right side flashes fast, all bulbs work. Need some help on locating the problem to fix.
Old Dec 18, 2008 | 11:47 AM
Timspony's Avatar
Timspony
SVT Section Moderator
...flashing fast means that the front or rear bulb is out on that side...I would just replace both to start!
Old Dec 18, 2008 | 01:27 PM
jbcorder's Avatar
jbcorder
I'll give that a try tonight.
Thanks.
Old Dec 19, 2008 | 08:18 AM
jbcorder's Avatar
jbcorder
Replaced bulbs....same problem....fast flashing on left side.
Any ideas?
Old Dec 20, 2008 | 10:49 PM
InferRedd's Avatar
InferRedd
My problem was a loose connection at the tail light side light bulbs. I wasn't sure at first so i bumped it whenever it started flashing fast and that fix it but it kept on happening. So I started messing around with all the connections and sure enough that is what it was.
Seanam
Oct 4, 2015 10:15 AM
mltdwn12
Sep 23, 2015 08:54 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
TfcCDR
Sep 14, 2015 12:08 PM
