Clutch issues *PISSED*
Old Jan 2, 2009 | 01:25 PM
jim135666's Avatar
jim135666
Default Clutch issues *PISSED*
So i went down to my local shop and explained to them that i need my clutch adjusted. They said i need a whole entire new clutch and i almost bugged out.
Detailed problem.
THE PROBLEM
My problem is not so bad. My clutch is simply engading too high (grabbing high). The pedal has to almost lift completely off the floor for the clutch to engadge. The result, i spin tire usually car if i dont give it a bit of gas it will just stall. Theyres no room to feather it. So my problem is i want to adjust the cable so the pedal grabs alot lower. As we stand the clutch does not slip (THANK GOD) well it does but only in donuts when i shift up which you shouldnt do anyways. The only problem i did have was when i geared down hard one day and smelled clutch and stopped instantly. I know its bad but i did it i stopped, all good. But anyways the shops trying to tell me i need a new clutch and i think thats a load of horse ****. Is it possible to adjust my cable tension to lower the pedal back to the floor and where it engadges. Cause im8 pretty sure theyres a way. Plus i saw kits to adjust the tension but im not sure if that helps my situation. I was also told to do the trick where you pull your pedal up except i do that and it just doesnt do anything. Please help : )
Sorry for going into such detail but if i lost some of you heres the short explinatiion. Clutch pedal grabs almost completely off the floor and i want to get it adjusted back to w here t grabs half way and the shops telling me thats not possible.
Old Jan 2, 2009 | 01:35 PM
briantlucas's Avatar
briantlucas
That sucks it might be the presure plate that is kind of what it sounds like anyways
Old Jan 2, 2009 | 01:45 PM
jim135666's Avatar
jim135666
really, i did my share of downgearing early in the clutch and it heated up alot but i stopped that months ago. I hope theyres a chance at adjustment
Old Jan 2, 2009 | 02:28 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Year of the car would be a big help so we know what we're dealing with!!
Old Jan 2, 2009 | 03:29 PM
jim135666's Avatar
jim135666
sorry its a 00'' GT with a king cobra clutch stage 1 if that helps
Old Jan 2, 2009 | 06:49 PM
Solitear's Avatar
Solitear
warped clucth/bad pressure plate maybe to me... idk might just be better to have another shop look at it...but thats what it sounds to me =/
Old Jan 3, 2009 | 06:22 AM
Jfsram's Avatar
Jfsram
The adjustment needs to be made looser to engage the disc earlier. A cable can be too tight but if it's too loose the first part of the travel does nothing. The cable may even fall off the hook. If you are at that point. Most likely the shops are correct. It's time for a new disc, pressure plate and resurface or replace flywheel.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
ccdguy
Sep 19, 2015 05:20 PM
PNYXPRESS
Sep 14, 2015 09:50 PM
MasterLanMan
Sep 13, 2015 08:21 PM
Emblazoned
Sep 3, 2015 10:45 PM
