8.8 Rearend
Old Jan 3, 2009 | 12:25 AM
Natedogg1087's Avatar
Natedogg1087
Default 8.8 Rearend
Hey guys i just need to know something? Does any one know if an 8.8 out of a 93 fox will bolt up under a 00 new edge stang? I'm talking as far as the Drive shaft, and suspension?
Old Jan 3, 2009 | 08:42 PM
akula's Avatar
akula
Basically yes. from what I have read on other forums the fox axles are a little shorter end to end. something like 3/4 inch per side so your tires will be further into the wheel well. Also there may be 2 holes for the control arms that have to be drilled larger but generally thats it.
Old Jan 4, 2009 | 12:55 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Yes it will work, and aside from what akula has said, you will have to make provisions for the disc brakes on the `00. I forget if the caliper brackets are welded on or pressed onto the end. But yes the d-shaft will bolt up, and the control arms/quads will line right up
Old Jan 4, 2009 | 10:12 AM
mustangman02232's Avatar
mustangman02232
you need to do a 5 lug swap, disc brake swap, and you will need wheel spacers
Matt's 95 Stang
Oct 5, 2015 07:16 AM
67LimeCoupe
Sep 30, 2015 04:46 PM
67LimeCoupe
Sep 21, 2015 06:34 PM
DCole24
Sep 11, 2015 10:50 AM
67LimeCoupe
Sep 2, 2015 08:02 AM
