2 questions..ac and speedo
Old Jun 5, 2005 | 12:54 PM
traps91gt's Avatar
traps91gt
Default 2 questions..ac and speedo
ok i just bought a 91 gt with a 302 bored to a 306..or this is what the dude told me.... suposed to have a e303 cam shorty headers no cats and a 3 inch exhaust. bbk cold air in fender not too sure on injector size but its also got a bbk fuel pump. ac has been removed...what do i need to re-install it? no pump compressor nuting is there. also...speedo dont work he told me it needs a gear cause he removed the old one when he put the 4.10's in it i have the gear...what do i need to do to get a speedo working again...also, anyone got an estimate on what this combo might put out in hp? this isnt my first stang but it is my first fox body with a 5.0...had 2 98's previous....thanx....mike
Old Jun 5, 2005 | 02:20 PM
86HOGT's Avatar
86HOGT
Default RE: 2 questions..ac and speedo
The speedo gear is really easy. Just follow the speedo cable back to the tailshaft of the transmission and therea one bolt holding it in. I think it's a 7/16" head. Then just pull the end of the cable out and remove the clip at the end by the gear (or where it should be) pop on the new gear, install the clip, put it back in, and bolt it back in.
Now for the A/C, how much has been taken out? If he went as far as taking out the evaporator core, you're in for a big, big job. If not then you need the accumulator, condenser, compressor, and lines. You'll want to get all new oil ring seals and an R-143A conversion kit.
67LimeCoupe
Nov 25, 2015 08:55 PM
Mr. D
Tuner Central
Aug 27, 2015 05:01 AM
Mr. D
Wheels & Tires
15
Aug 22, 2015 02:58 PM
Gregz
Aug 11, 2015 03:42 AM
qwikhuh
Dec 1, 2003 04:26 PM
