problems after replacing heater core. NEED HELP!
Old Jan 8, 2009 | 06:39 PM
navymm1swaw's Avatar
navymm1swaw
Question problems after replacing heater core. NEED HELP!
In these hard times, I am trying to save a buck by doing the work myself. With that, I decided to replace my heater core instead of paying the $1200 for the shop to do it. All was well with my 97 Mustang GT except for the heater core. I removed the dash and replaced the core. Put it all back together and now my airbag flashes error code 41 (RH side open circuit) and my alternator is not charging. I took the alternator to have it tested and it checked fine. I put it back in the car thinking it might have been a loose regulator plug, but it is still not charging. I checked all of the quick connects and all seem to be together. I am at a loss. Please help. What should I check now??
Old Jan 8, 2009 | 06:48 PM
myounts's Avatar
myounts
Check your fuses underneath the driver's side dash. If you are for sure that you have everything connected, then that's a good place to start.
Old Jan 8, 2009 | 07:11 PM
navymm1swaw
Default fuses check good
Just checked under the dash and, for good measure, the fuses under the hood. All checked out to be good.
Old May 8, 2009 | 10:44 AM
green87's Avatar
green87
did you ever figure out what the problem was? i am having the same exact problem as of right now everything is showing good but i cant get it to charge, and i also just replaced my heater core... let me know if you figured it out... maybe you could email me
christopher.stocking@hotmail.com
87' 5.0
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
Calizic
Aug 28, 2015 01:46 PM
philster0306
Aug 10, 2015 11:33 AM
Mnuckolls
Aug 9, 2015 08:54 AM
