Sponsored by:
Sponsored by: DashLynx
new autometer gauge not working
Old 06-06-2005, 05:44 PM
luckythirteen13
luckythirteen13's Avatar
Default new autometer gauge not working
just put in my autometer electric water temp gauge yesterday. i drove it today and it went all the way up to 210 and stopped. i dont think im running at 210 cause i have a 180* thermostat (mr. gasket), a new water pump and new radiator. the factory gauge (with new sending unit) is reading one dash under the middle point. also, when my stat opens, the factory gauge drops but the autometer just keeps going up till 210. also, when the factory gauge read 130, the autometer wasnt even reading 100 yet. should i call summit or autometer? i checked all the wires and they are fine. i know i didnt ruin the sender cause the batter was disconnected when i hooked it all up
the factory sender is in the front of the manifold in the stock location, the autometer sender is at the back of the manifold where there used to be a plug. both are on the drivers side
luckythirteen13 is offline
Old 06-06-2005, 05:58 PM
DIVER8374
DIVER8374's Avatar
Default RE: new autometer gauge not working
I believe that you are reading a hotter temp because of the location of your temp gauge being on the back of the manifold. (I might be wrong on that) I am working on installing one in my car and am going to have a friend weld a button to a new thermostat houseing and drill and tap that for the new sending unit that came with my autometer gauge.
DIVER8374 is offline
Old 06-06-2005, 11:10 PM
fordguy17
fordguy17's Avatar
put it at the front where the stock one was. it will give you more accurate readings.
fordguy17 is offline
Old 06-07-2005, 04:24 PM
99saleen351r
99saleen351r's Avatar
could be a bad ground.
99saleen351r is offline
Old 06-08-2005, 03:57 AM
luckythirteen13
i thought about that but i figured it wouldnt even work if it wasnt grounded right
Old 06-08-2005, 02:03 PM
99saleen351r
Try puuting a hose clamp around the sender with a stripped wire under the clamp and run it to the battery ground and see if it works right if it does you know its the ground.
Mobiusone stang
09-07-2015 08:46 PM
TimeLord101
09-04-2015 09:27 AM
raleigh05GTO
09-04-2015 07:09 AM
cbird1177711
09-03-2015 08:43 PM
09-01-2015 08:16 PM
Quick Reply: new autometer gauge not working
