How the @%$#& to get those A/C spring clips off
hey guys, got a 98 V6 and trying to replace an A/C line. I've got an A/C line spring coupling tool but I can barely get it into the coupling to loosen it up. is it that difficult? what's the trick? please help!
There is no trick....just take the ac line tool or a fuel line tool and right size slide into the end of the coupler and you'll feel it pop in....then pull them apart....no pliers. Same exact thing as fuel lines if you have every disconnected those.
I've got 2 different tools that say A/C spring coupling tool so I have the tools. I pick the right size, I think, 1/2" by the firewall, 3/8" by the condenser. I just can't get them to pop in. Will try again today. Thanks for the feedback.
should I heat the joint up with a hair dryer? WD-40?
oh, haven't done fuel lines before, just got the car recently
I've used some elbow grease and pliers on those babies and the stronger springs; like the coolant lines, it works after a while.
