Alternator issues with my 2005 Ford Focus.
Old Jan 24, 2009 | 01:50 PM
Bmr4life's Avatar
Bmr4life
Default Alternator issues with my 2005 Ford Focus.
Okay here's the story.
Car has needed about 10 jumps in the past 2 years. Driven almost everyday, but only for 2 miles most of the time with a single 80 mile round trip once a week.
Replaced the battery 2 weeks ago. After one week, new battery needed a jump 3-4 times in a single day. It was around 20 degrees that day. Same day car dies while on the freeway. Jumped it again and got it to a friends house nearby. Few days later, I swapped out the new battery for the Optima Red Top from my Mustang. Got both car's home with no problems. Had the new battery tested and it checked out fine and has been in my Mustang for a week and hasn't shown a single sign of trouble.
Red Top in Focus hasn't shown a sign of trouble either.
I've tried the following to test the alternator. Remove negative battery cable while car is idling. Car stays on. BUT, if I then turn the headlights on, car immediately dies even if I'm revving the motor.
Battery light in the Focus has never come on.
Old Jan 26, 2009 | 11:42 AM
yial's Avatar
yial
Sounds like it's your alternator. Almost exact same thing happened when my alternator went for the second time. See if you can get it to a garage or auto parts store that'll test it for you. It should be a free test that takes all of thirty seconds.
Old Jan 26, 2009 | 12:19 PM
Bmr4life's Avatar
Bmr4life
That was my plan this weekend, but about an hour into trying to get it out I realized it was pretty much impossible. Its down in the bottom of the engine by the fire wall. I had already moved the steering and coolant reservoirs as well as the exhaust heat shield only to find out you have to under a motor mount and lift the engine up to wiggle it out of there. I figured I could get it out, but probably would be able to get it back in.
We'll see how long it runs with the Red Top in there. If it dies again its going to a shop.
Old Jan 26, 2009 | 07:36 PM
yial's Avatar
yial
Depending where you live, you might be able to drive the car to a mechanic/store that can test it while it's on the car. I've never had an alternator tested off my car as I only live two blocks away from a Fisher auto parts store.
soulcaliber39
Dec 28, 2016 04:57 AM
overnight89
Aug 22, 2015 09:02 PM
rakesh544
Aug 19, 2015 06:23 AM
jjwinel78
Aug 17, 2015 03:34 PM
mweiland
Aug 13, 2015 05:11 PM
