308 gears info
Old Jun 8, 2005 | 02:38 AM
flamin87's Avatar
flamin87
Default 308 gears info
how good are 308 gears ? i know the popular ones are 3.55 or 3.73. I got a new set of 3.08 gears in a swap meet for $10 need info on theses numbers. need to know if they are good for 1/4 mile? if not i could use them for desk ornaments. thanx
Old Jun 8, 2005 | 02:51 AM
91LXstanger's Avatar
91LXstanger
Default RE: 308 gears info
For 1/4 mile times ur MUCH better off with 3.73's or 4.10's if ur n/a. If ur blown or juiced 3.55's are good. And the stock manual trannys come with 3.08's. So id just sell those for more money , then grab some 3.73's. They're great on the street and dont affect highway driving too much.
Old Jun 8, 2005 | 02:57 AM
Eric @ DMS's Avatar
Eric @ DMS
As 91LX said...I would go 4.10s at the track if you're a manual. Otherwise, I'd go 3.73s if auto. If you're blown/nitroused then taller gears may be too much for the track.
Old Jun 8, 2005 | 08:53 AM
Quik's Avatar
Quik
why you think you paid 10 bucks for them..................everyone has them and now so do you
Old Jun 8, 2005 | 02:18 PM
flamin87's Avatar
flamin87
thanks, right now the motor i have ill be using 100 shot n2o i have edelbrock aluminum heads, crane rockers, polished crank, pulleys headers etc. i think ill be getting the 3.55s cuz my next motor in working on will be either a 460 with turbo or a stroked 351w but im turbocharging this time. does any body know with the motor i have now how much more shot i could go with blowing **** up?
Old Jun 8, 2005 | 03:43 PM
91LXstanger
Forget power upgrades right now....get a sh*tload of suspension work done.
Old Jun 9, 2005 | 12:48 AM
86gt5.0HO's Avatar
86gt5.0HO
you will probly want 3.27's or 3.08's for a 460. Even if it's not that built they are torque monsters and like to rev low and PULL. I have a 425CI in my '78 caddy with stock 2.28's (posi). The motor is slightly cammed with flat tops and 4BBL, and it still breaks the tires loose when you stomp it at 30-40 kph. The motor makes it's power from 1500- 4000 RPM's.
Old Jun 9, 2005 | 02:33 PM
flamin87's Avatar
flamin87
sorry for the delay i couldnt find my post. well on the 87 gt i have running now eibach spring, sub connectors and steeda upper and lower control arms. any recomendations. looking at a tubular k member and A arms. for the big block project i need to do sme more reaserch on suspension upgrades.
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
RCS02v6
Sep 29, 2015 01:46 PM
junior04
Sep 28, 2015 10:53 AM
