side exhaust
Old Feb 6, 2009 | 05:00 PM
thePH03NIX's Avatar
thePH03NIX
uhhh.....what?
Old Feb 6, 2009 | 10:00 PM
USMC1775's Avatar
USMC1775
I had side exit before with the Eibach Prokit, and I scraped on EVERYTHING, both my relocated mufflers and the tips. So I moved the mufflers back and went to dumps with my Sportlines.
Old Feb 6, 2009 | 11:19 PM
thePH03NIX's Avatar
thePH03NIX
really now... did you have sideskirts for the exhaust? or did you have it coming out below your stock sideskirts?
Old Feb 8, 2009 | 12:47 PM
USMC1775's Avatar
USMC1775
Came out below the stockers, since I couldnt find the SVOs anywhere.. That didnt make them hang any lower since the SVOs are the same as the stockers, just with the lower part to flank the exhaust pipe.
I eventually cut off the 3" tips, and left the pipes about 6" from the side, for more clearance, then realized that that didnt help so I did away with it all. I wish there was a better way, just not with the funds the way they are now. In the future, Id love to re do it with some mandrel bent oval piping to make it work.
Old Feb 8, 2009 | 02:21 PM
thePH03NIX's Avatar
thePH03NIX
well the way my mufflers are set up, it has an inlet and an outlet on the same side, so the mufflers are in the same position they would normally be in, so do you think that would make a difference when i lower my car? or will i probably scrape on everything as well..?
Old Feb 8, 2009 | 10:24 PM
USMC1775's Avatar
USMC1775
That kind of muffler might work better for you, depending on the size pipe you use. If you have the Prokit and 2.5" pipes youll be fine I think.
Galactic
Apr 29, 2019 02:56 PM
GentleBen
Sep 11, 2015 05:34 AM
Sep 10, 2015 08:39 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
TimeLord101
Sep 4, 2015 09:27 AM
