Low MPG
Old Feb 1, 2009 | 08:35 PM
Juno's Avatar
Juno
Default Low MPG
Hello, i got an Dodge Grand Caravan from 1996...
Everything was great till some day... Now im making 140 Miles on tank with regular city driving (Low RPM's ETC) Before that i was making 250-300 Miles on tank.
It sucks...
Maybe you had problem like this?
Thankx
Old Feb 1, 2009 | 09:08 PM
03Mustang281ci's Avatar
03Mustang281ci
You must mean 14 MPG. Because what you said is not possible o.O maybe it will be in 100 years but not right now lol How many miles are on the van and are they the original spark plugs? Or it might be something as simple as a bad tank of gas, dirty fuel injectors, try some fuel system cleaner. Have you noticed a loss in power? thats another good question.
Old Feb 1, 2009 | 09:13 PM
Juno's Avatar
Juno
140 Miles on tank my bad...
Van has 136k...
Spark plugs are okay, i dont know about fuel injectors.
Is the fuel system cleaner safe for a car?
No, no loss in power.
Old Feb 1, 2009 | 09:53 PM
mustangcat's Avatar
mustangcat
Deputy CatDog - To Purr'tect and Explode
Van has 136k...
Yeah, fuel injector cleaners are fine. You can get them at Wal Mart, Autozone, Checker, etc.
Run around $5.
Check your tire pressure. Air filter.
Old Feb 1, 2009 | 11:27 PM
Juno's Avatar
Juno
Tire pressure is good, i changed Air Filter about 2 years ago so its still okay
Old Feb 1, 2009 | 11:59 PM
08SGT's Avatar
08SGT
check the fuel filter ?
Old Feb 2, 2009 | 11:26 AM
Timspony's Avatar
Timspony
SVT Section Moderator
Sounds like you need an OVERALL tune-up...+ you're going to loose 2-3 mpg in the cold weather...
Old Feb 2, 2009 | 12:16 PM
945LSTANG's Avatar
945LSTANG
hopefully that van doesnt turn out to be a PITA like ours was.
we used to have a 96 grand caravan and it was constantly in the shop. because of it my dad will never buy another american car.
Old Feb 2, 2009 | 12:49 PM
mustangcat's Avatar
mustangcat
heh what?
Cold air is denser, so it contains more oxygen, which means engines have to work less to get that needed oxygen, getting better gas mileage and more horsepower.
And Juno, it may be time to look into getting a higher octane gas. Regular is fine for normal mileage vehicles, but I've noticed once a car gets high mileage if you bump the octane to Plus you should squeeze out a few more MPG.
Old Feb 2, 2009 | 06:30 PM
MustangLouver's Avatar
MustangLouver
Make sure spark plugs are clean, all filters are clean. Try fuel injector cleaner, and run higher octane fuel, I know I get 3-4 MPG better with Premium grade over reg. Pretty much what everyone else said, but just do you routine checks.
