pulleys
Old Jun 9, 2005 | 03:51 AM
ekthrilla's Avatar
ekthrilla
Default pulleys
i need help getting the idler pully off. It is the pulley that has no lips on it and it is connected to the power steering pump but not the power steering pulley. its like a star shaped tool.
Old Jun 9, 2005 | 09:34 AM
AtlanticBlue99's Avatar
AtlanticBlue99
I ♥ Acer
Default RE: pulleys
is it bolted on? i dont have the 4.6L, so i cant really help. if it is bolted on, find the type of bolt (torx, hex...) then break it free. i know my crank pulley had to be removed with a puller when i changed it out...
Old Jun 9, 2005 | 12:32 PM
99saleen351r's Avatar
99saleen351r
Default RE: pulleys
Are you talkin the tensioner pulley if so its bolted with three bolts around the outer edge,thats the easiest one to remove.
Old Jun 9, 2005 | 07:37 PM
AtlanticBlue99
I ♥ Acer
Default RE: pulleys
i have one idle pulley on my 3.8L, it is next to the alternator.
Old Jun 9, 2005 | 11:32 PM
72MachOne99GT's Avatar
72MachOne99GT
2010 Blue Ball Award Recipient
Default RE: pulleys
Is this part known to be a big squeaker..?
i have a squeak from under the hood, sounds like one of the pulleys,,
i believe its one of them on the left side, and kinda higher positioned,, and since i have nearly no idea what each pully is for or does, i'll just leave it at that...
thanks....4.6 by the way
GimpyHSHS
19
Dec 19, 2023 01:12 PM
spdeplayer2
Oct 24, 2015 09:45 AM
FivePointToTheOh
Sep 29, 2015 12:53 PM
mikesr4565
Suspension
Sep 21, 2015 10:26 AM
ctgreddy
Sep 20, 2015 08:35 PM
