fan clutch
Old Jun 9, 2005 | 04:29 AM
Crazyfast50stang's Avatar
Crazyfast50stang
Default fan clutch
Ok stupid question but what is the fan clutch? Where is it and what does it do?
Old Jun 9, 2005 | 12:30 PM
99saleen351r's Avatar
99saleen351r
Default RE: fan clutch
The fan clutch is on the fan its lets it stop spining when the motor doesnt need the fan.If you try to spin the fan you'll notice it spins freely but out of nowhere when its running it locks up and starts spinning.Once in a while they will wear out and the fan will stay on all the time.Thats why they have the warning label (fan may turn on at anytime)
Old Jun 9, 2005 | 03:35 PM
Crazyfast50stang
ok cool thanks.
Old Jun 9, 2005 | 07:36 PM
mrbmp's Avatar
mrbmp
I ♥ Acer
That would be the label on an electric fan, which do not have clutches.
The fan clutch is the finned aluminum thingy between your radiator fan and water pump.
When working properly it varies the amount of torque applied from the water pump shaft to the fan itself, the warmer it is the more torque it applies (spins the fan faster) .
Usually when they go bad they dont transmit enough torque (fan spins slow) and engine runs hot especially if you are in stop and go traffic.
The best thing to do if your fan clutch goes bad is remove the fan and clutch and install an electric fan.
BOB ROME
Jul 26, 2023 01:54 PM
PaulH2
20
Jan 31, 2016 09:48 AM
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
Sep 25, 2015 09:06 AM
