rough idle when warm
Old Feb 7, 2009 | 08:55 PM
deaverj's Avatar
deaverj
Default rough idle when warm
hey guys i have a 91 lx 5.0 pretty much stock other than intake and exhaust.when cold it runs just fine but when it get warm it starts running rough then it starts missing and back firing out the exhaust. im just trying to get some ideas to figure out the problem
Old Feb 8, 2009 | 08:52 AM
ryan1994mustang's Avatar
ryan1994mustang
sounds like it could be the EGR valve, any check engine lights?
Old Feb 8, 2009 | 08:10 PM
deaverj's Avatar
deaverj
i found my problem it was a combination of bad and loose plugs i went to pull the #5 plug and i could turn it with my fingers that was the only one but the rest were just tight enough you couldnt get them out but one turn of the ratchet then you could. so i replaced all of the plugs and went to make sure the timing was set right just to find out the distributor cap was loose so tightened that down started it up waited for it to warm up and nothing it ran just fine no problems
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
svfetter
Oct 5, 2015 11:39 AM
MacSerio
Sep 27, 2015 01:05 PM
