car won't turn over...click, click
Old Feb 10, 2009 | 05:20 PM
92stangerang's Avatar
92stangerang
Default car won't turn over...click, click
so ive bean dealing with this issue for some time now. so far ive replaced the battery, battery cables, starter, starter solnoid,starter cable. pretty much everything that turns the car over. sometimes it will just barely turn the motor over(like one revolution, like the battery is dead) the battery is new and been on the charger for two days now. what gives? when i jump the solinoid it starts to smoke.
Old Feb 10, 2009 | 05:27 PM
Monkeyleg's Avatar
Monkeyleg
First off, are you sure you're jumping the solenoid the right way?
It's possible that you just may have a bad battery, even if it's new. I had that happen to me a couple of months ago.
If the battery is holding a charge for a while, and is able to turn the motor over, then you might have some other problems. The voltage regulator on the alternator may be allowing the battery to leak down. You might also have a light or other low-amp accessory that draws down power from the battery over a period of hours. Or you just may have a short in the wiring somewhere.
Electrical stuff is fun, isn't it?
Years back I got a nice van from the company I worked for. It was doing the same thing. I bought the van for $500 and replaced the switch for the dome light that was keeping the light on all night. When my boss found out I fixed it for maybe $15, he was ticked.
Old Feb 10, 2009 | 05:31 PM
Timspony's Avatar
Timspony
SVT Section Moderator
...disconnect the battery and check the connection on the starter! ...sure does sound like a battery..also check your grounds!
Old Feb 10, 2009 | 05:59 PM
Demon 340's Avatar
Demon 340
Administrator
find someone with a volt meter. check the output on the battery hooked up, then take the cables off. i had a problem with an electrical short, and even with a brand new battery in the car, it would just click...i found the short and removed it, and it was fine.
also, with the battery hooked up, turn on something like the lights, or the heater...if the battery goes way down when you do this, and continues to drop, its likely a bad battery.
Old Feb 12, 2009 | 12:26 PM
junkrider's Avatar
junkrider
YES, grounds! The must be a ground from the batter to the block directly. You are talking a heck of a lot of current. Must be in excellent shape.
Check voltage from battery + to -, then from + to engine block, then from + to body. For the heck of it, check to the starter housing, too. + to starter housing. (did you paint the housing, block or bell housing???).
The voltages should all be the same key off, then repeat key on. Then repeat while attempting to crank.
Write the voltages down, and post them...
Oh, and check the voltage from "-" at battery to your solenoid, at the battery side, then at the side running to the starter with the actual cable off the solenoid (disconnect the cable running to the starter at the solenoid). Write those down, too.
Good luck. Electrical is fun, and makes for great deals when it is bad.
MXBT187
Aug 20, 2015 02:36 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
ccwebb
Aug 11, 2015 06:47 PM
