Brake help
Old Jun 10, 2005 | 06:48 PM
van131's Avatar
van131
Default Brake help
Installed new brakes all the way around bled system and still have pedal travel anyone out there that can help
2002 Mustang V6 3.8
Old Jun 10, 2005 | 07:11 PM
73Cleveland's Avatar
73Cleveland
Default RE: Brake help
Do you have any pedal at all?
Did you replace calipers?
Which order did you bleed the brakes?
Old Jun 10, 2005 | 07:20 PM
van131's Avatar
van131
yea it goes 3/4 down
but it stops great
this started happening when i replaced the front brakes
right left
left right
there was no air it bled like hell
is there a way to ajust the brake pedal?
Old Jun 10, 2005 | 07:28 PM
73Cleveland
Did you have that low a pedal before you did the brakes?
What did you replace? Pads, calipers, or both?
Did you remember to re-fill the master cylinder while you were bleeding the system?
Old Jun 10, 2005 | 07:29 PM
van131's Avatar
van131
no not before i did the brakes
Just the pads
and filled cylinder
Old Jun 10, 2005 | 07:33 PM
73Cleveland
If you didnt replace the calipers, you shouldnt have had to bleed the brakes.
Did you bleed the brakes cause the pedal was low after you changed them?
If the pads are installed correctly, you should have only had to pump the brakes a couple of times to fill the piston in the calipers. No bleeding would be needed. That should have given you as good a pedal as you had before you changed the pads.
Old Jun 10, 2005 | 07:36 PM
van131's Avatar
van131
i bled the brakes cause the pedal was low
Old Jun 10, 2005 | 07:53 PM
73Cleveland
Sounds ike you have a bunch of air in the lines or the master cylinder decided to go bad. I think it's most likely air.
If you cant get it out you may have to get it power bled in a shop.
When you are bleeding the brakes, are making sure the pedal is all the way to the floor and held there until the bleeder valve is tightened? If you let it up before the valve is tightened, you will suck lots of air back into the system.
Old Jun 10, 2005 | 08:22 PM
van131's Avatar
van131
how can i check if its the master cylinder
yea i made sure it was tightened
Old Jun 10, 2005 | 11:03 PM
73Cleveland
Since it was working ok before you changed the pads & bled the lines, I'm thinking it's still got air in the line.
If you pump the brakes several times, does the pedal get any better?
