Aftermarket K-Frames???
Old Feb 28, 2009 | 10:46 AM
capri_83's Avatar
capri_83
Default Aftermarket K-Frames???
I want to install an Aftermarket K-Frame and I see that some say that you can use the factory control arm but what about the spring?? Do you have to change to coil overs??? I've look at a few different supplier and none of them(K-Frames) have upper spring pockets. so is it possible to use factory springs??? Thanks
Old Feb 28, 2009 | 03:29 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
What are the goals for your ride and why are you looking for a new "K" member install?
Installing a new tube "K" and NOT re-placing the stock "A" arms, is not getting the full benifit of the upgrade. The stock "A" arms are flexable and have soft rubber bushings allowing less than ideal handling. Most aftermarket "K"s are going to require their own "A" arms, but don't have a spring perch. This means you probably need to make a decision on going CO's or not.
There is no disadvantage to going CO's except for cost. You will get a much better wheel rate and hence a nicer ride and better handling if you choose wisely. You will also get a wonderful array of height adjustments to go from snakes-belly to Mac truck if you like.
I would contact MM as they can ask the questions you need to answer to get one. There are generally two directios to go. One for 1/4 mile applications and one for street/cornering.
HTH
Jazzer
Old Mar 2, 2009 | 12:56 PM
capri_83's Avatar
capri_83
Thanks the car was hit and the only thing out to lunch is the k-frame. Car is not anything more than a street car so cost is a factor. I will just pull a stock k-frame from a parts car Thanks again
Old Mar 2, 2009 | 12:57 PM
capri_83's Avatar
capri_83
BTW this is NOT my Capri it's a '79 5.0 I picked up..
Dan04COBRA
Sep 30, 2015 11:46 AM
wraith777
Sep 28, 2015 10:49 AM
Sep 24, 2015 09:18 PM
Sep 17, 2015 07:32 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
