sn-95 headlight removal
Old Mar 24, 2009 | 09:44 PM
1bad87's Avatar
1bad87
Default sn-95 headlight removal
Trying to put new headlights into my 95 gt and cannot figure out how to get the stocks out. anyone have a how to or able to give me some insight? thanks!
Old Mar 25, 2009 | 04:58 AM
95greengt's Avatar
95greengt
on mine if you look at the adjuster on the back of the light there are small locking tabs which can be released then you can just slide out the headlight
Old Mar 25, 2009 | 05:07 AM
95greengt's Avatar
95greengt
http://www.mustangevolution.com/articles/200755/
this may help you out
Old Mar 25, 2009 | 05:41 AM
1bad87's Avatar
1bad87
great thanks man! gonna try to get em changed this morning!
Old Mar 26, 2009 | 06:23 PM
Stang9946's Avatar
Stang9946
I changed my left side last Tuesday. On the inner corner (farthest from the side marker) there is one push pin/clip and two on the side closest to the side marker. To make ur life easier, take off/out the side marker...this will make it easier to put the new one in. One of the push pin things has a clip...it's the top one closest to the side marker. Pull the clip up. That one is done. The one below that and the one closest to the center of the car require you pinch the 2 side tabs together to pull the light out. Put something under the light to help prevent scratching the paint when pulling the light out. Pull it out straight and evenly. Having a second person will help but is not required. Obviously unplug the light wires as well. When putting it back in, same thing, push it in straight and make sure the "groves" on the car slide in straight with the groves on the light adjustment arms. ALSO!!! don't forget....adjust the adjustment screws on the new light to match the old one you took out to as close as you can get. This will make your life a bit easier in a long run. Just line everything up straight and evenly. Once you realize what to do it should take you about 10 minutes. Cheers. Good luck.
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
Drastang
Sep 29, 2015 03:31 PM
