Old Oct 23, 2015, 03:17 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Steering & Suspension Guides
Print Wikipost
Replacing Ball Joints is a Ball Buster
Old May 2, 2009 | 06:33 PM
paj954's Avatar
paj954
Default Replacing Ball Joints is a Ball Buster
OK, I have read all the post that replacing ball joints is easy, Bull Sh@#. I can't get the control arm off of the ball joint bolt or the tie rod bolt.
Any help would be appriciated
1995 Mustang Convt. 3.8L
Old May 2, 2009 | 06:57 PM
945LSTANG's Avatar
945LSTANG
what tools are you using?
Old May 2, 2009 | 07:25 PM
blike's Avatar
blike
Why are you removing the control arm?
You need to simply remove the spindle, and press out the balljoint with a balljoint press. You can rent a balljoint press at your local part store, and this procedure should take about 3-4 hours your first time through.
Old May 2, 2009 | 08:45 PM
mudvayne1's Avatar
mudvayne1
Why are you taking the control arm off? Replacing a ball joint is simple yet aggravating. I had to change one of mine a month or 2 ago and I just took a torch and cut it out. Be careful not to cut the control arm though. It'd probably be easier just to rent a ball joint press.
Old May 3, 2009 | 07:00 AM
paj954's Avatar
paj954
I have a Ball Joint Press, but can not figure out how to use it to remove the old ball joint. Part of the control arm is in the way. I removed the control arm because someone on this site advised me to.
Look this is the first time I ever changed ball joints, does anyone out there have instructions on how to use the ball joint press?
Old May 3, 2009 | 07:05 AM
paj954's Avatar
paj954
not the control arm, what do you call the part that the rotor attaches to? I have to remove this, right?
Old May 3, 2009 | 08:11 AM
paj954's Avatar
paj954
go to next post for picture
Old May 3, 2009 | 08:55 AM
paj954's Avatar
paj954
Default Picture of Ball Joint
http://www.flickr.com/photos/37986272@N05/3497285208/
Last edited by paj954; May 3, 2009 at 09:02 AM. Reason: Site Where Picture Is Located
Old May 3, 2009 | 09:00 AM
paj954's Avatar
paj954
As you can see I can not get the ball joint out
Old May 3, 2009 | 10:18 AM
mudvayne1's Avatar
mudvayne1
Just pick that up and off the ball joint and press it out of the bottom.
