The power just is not there...
Hey guys i just installed a set a world products windsor jr heads. My mods are Gt40 upper and lower manifolds. 24lb injectors. 70mm TB, 75 mm mass air flow, smog pump delete, small cam, not sure wat one, and headmen headers with full exhaust.
i originally had stock E7 heads. i now have the world products windsor jr heads with 58cc combustion chamber also adding harland sharp 1.6 ratio full roller rockers. My problem is that the power just is not there, its like it did nothing. idk what could be causing this. i know that there is a fresh air opening on the back of the heads that is not yet plugged butcould that really make that much difference. i also considered the timing. but i have it set as far advanced as it will go without any pinging. any help would be much appreciated
KingRando
10-02-2015 08:06 AM
09-25-2015 06:58 PM
