Electric fan question. (Manual switch or continuous?)
Old Jun 9, 2009 | 02:09 AM
vvelez5's Avatar
vvelez5
Default Electric fan question. (Manual switch or continuous?)
I'm planning to install an electric fan in my 91 mustang 5.0, but i know some people put in a manual switch instead of hooking up the fan to the ignition. Why is this? Is this so the car wont run too cool? doubt it but just asking.
Old Jun 10, 2009 | 02:31 AM
Jfsram's Avatar
Jfsram
It's because it's a total waste of electricity which in your case is alternator draw.
The total concept behind and electric fan is it only draws power when you need air flow through the radiator to cool the engine. Whenever the thermostat is closed, you don't need it. Whenever you are driving about around 45mph, you don't need it. When you stop, like at a red light. For the first few seconds, you don't need it.
Automatic controller is the ONLY way to go here.
Old Jun 10, 2009 | 06:35 PM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
I had to install a manuel one on my 85 2.3 because the fan would not kick on until the engine was to hot. I actually blew my top rad hose because the fan did not kick on. I think manuel is a very good idea as a back up.
Matthew
Old Jun 12, 2009 | 08:14 PM
93_five_oh's Avatar
93_five_oh
painless and flexalite make automatic thermostats... i think they are even adjustable.
you could always wire in a bypass switch too so you can turn it on whenever you want.
Old Jun 13, 2009 | 08:57 PM
87notch408's Avatar
87notch408
I have a painless adjustable going in mine and have installed them in quite a few other projects. My opinion they are the only way to go. If it is manual only you run the risk of forgetting to turn it on and there is no need for continuous (besides the fact that it will cause premature wear on the fan.
Old Jun 13, 2009 | 09:23 PM
67mustang302's Avatar
67mustang302
I'm running a basic Jegs universal adjustable. Like has been mentioned, automatic control is the only way to go. With an adjustable you can set when you want the fan to come on, and it only comes on when you need it. You have to remember than a fan draws a crapload of amperage(mine for instance operates on 19A, most basic factory fans will run on at LEAST 10A), and more amperage being drawn means more alternator load, which means a stronger magnetic field which means more parasitic loss. If you run a constant on electric fan you might as well just run a mechanical fan. And a manual switch only is asking for trouble, the first time you forget to turn it on you won't know until you overheat.
Old Jun 13, 2009 | 09:32 PM
badloser's Avatar
badloser
what he said....
tmdm
May 2, 2021 02:49 PM
PNYXPRESS
Sep 14, 2015 09:50 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Mustangmalo
Sep 6, 2015 05:22 PM
