T-5 Vs. T-56
Old Jun 19, 2009 | 09:38 AM
StuntDrivin4U's Avatar
StuntDrivin4U
Default T-5 Vs. T-56
I was wondering what you all think about this issue? Application would say be daily driving and weekend track fun and everything in between. Was kinda of unsure which path i should choose, I have a few buddies with the Tremec TKO 5spd in their fox body and I was wondering if I should just go for something different or if Tremec is really the way to go. Modification is no issue. Just oppinions on the situation would be rad!!
Stunt
Old Jun 19, 2009 | 10:27 AM
USMC1775's Avatar
USMC1775
t56 is nice...? Is that what youre wondering?
Old Jun 19, 2009 | 12:05 PM
Drag5.0mustang's Avatar
Drag5.0mustang
From: Parrish,Brandenton,Tampa,Florida,Gratiot Michigan
t-56s are pretty strong.
Old Jun 19, 2009 | 04:52 PM
StuntDrivin4U
ya just wondering how reliable they are and if it would be a good choice to throw in there
Old Jun 19, 2009 | 07:02 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
I broke a T56 with less than 400 rwhp, they are not as strong as people think, unless you upgrade the internals. Also keep in mind the final drive ratio is not much different than a T5.
BTW Tremec makes the TKO, the T5 and the T56.
Old Jun 19, 2009 | 08:04 PM
945LSTANG's Avatar
945LSTANG
did you have the stock 10 spline input shaft or the upgraded 26?
Old Jun 20, 2009 | 03:36 PM
JD1969's Avatar
JD1969
It was 100%. It was when I owned my 2001 Camaro SS. I just see a ton of people who think these trans are the end all be all, just because they have 6 gears. More is not always better, I think I only used 6th gear a couple times in that car.
Old Jun 20, 2009 | 09:41 PM
945LSTANG's Avatar
945LSTANG
i agree that they aren't the hottest thing out there, but with a 26 spline input shaft they can hold their own...
Old Jun 21, 2009 | 09:35 AM
JD1969's Avatar
JD1969
I killed the 3rd gear syncros and blocker rings. Input shaft was fine.
Old Jun 22, 2009 | 09:47 AM
StuntDrivin4U
Those TKO trans are rediculously strong, Ive seen the T56 out there but havent heard much fuss about them where as many swear by th TKO T-5
