Engine Swap Questions
Old Jun 29, 2009 | 08:38 PM
fullofquestions403's Avatar
fullofquestions403
Default Engine Swap Questions
Ok, so i bought an 88 LX, i have a 351 cleveland to put in it, so i want to pull the 4 banger out and put it in there. My question is am i gonna have any issues making it fit aside from the obvious? Am i gonna have to pull the motor to change plugs?
Old Jun 29, 2009 | 09:01 PM
socalwrench's Avatar
socalwrench
It's a tight fit, but with a nice u-joint and extension- you should be fine changing plugs. I'm sure there are pictures of a FOX with a V8 in it.
Just be sure that the rest of the drivetrain can handle the torque from the V8, and that your brakes are sufficient for the extra weight.
Old Jun 29, 2009 | 09:37 PM
fullofquestions403
yeah thats all being upgraded, i just wondered how tight it was gonna be and whether i should look at a 302 instead, but if itll fit then ill stick with the 351
Old Jun 29, 2009 | 10:10 PM
socalwrench
I don't believe there's much difference in width between the 302 and 351w. If I recall, the heads are taller, but it shouldn't be a problem.
Old Jun 30, 2009 | 12:12 AM
mudvayne1's Avatar
mudvayne1
351w is a little wider and taller but fits in fox bodies. Only mods are headers designed for that specific swap, taller hood, and different oil pan.
I'm not sure about the cleveland though.
YoungStangsMan
Sep 5, 2015 07:01 PM
classic69FB
Aug 12, 2015 11:58 PM
StangMuscle
Aug 12, 2015 07:27 AM
Jacob4589
Aug 8, 2015 11:00 AM
