leaking differential fluid
Old Jul 9, 2009 | 07:53 PM
tator152's Avatar
tator152
Default leaking differential fluid
well i just bought my stang about a month ago (2002 GT). a little while later i noticed a kind of clunk noise coming from the rear when i put it in reverse. now it is leaking differential fluid. Any help would be much appreciated! Thanks
Old Jul 9, 2009 | 08:16 PM
AirBrontosaurus's Avatar
AirBrontosaurus
Do you want help on what the cause was or help on how to fix the leak and replace the oil?
Old Jul 9, 2009 | 08:28 PM
USMC1775's Avatar
USMC1775
Block the front wheels, jack and support the back of the car, and pull the diff cover (with a drain pan underneath). Check for any damage on the gears, excessive play, or anything like that, as well as inspect the fluid for chunks of metal. Then reseal that bish with a gasket/sealant/both, and refill fluid via the full plug on the front of the pumpkin (use a 3/8 ratchet exension to get the plug out). Fill fluid until it comes out of the filler hole.
And dont forget the friction modifier
Old Jul 9, 2009 | 09:46 PM
socalwrench's Avatar
socalwrench
Friction modifier would be needed for a limited slip differential.
The clunking could be excessive backlash or worn out pinion bearings.
Old Jul 9, 2009 | 10:25 PM
tator152's Avatar
tator152
thanks for the help guys! and to airbrontosaurus, any help on what could be causing this and/or how to fix would be appreciated
jerrytubes
Oct 23, 2015 12:11 PM
KingRando
Oct 2, 2015 08:06 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
wraith777
Sep 28, 2015 10:49 AM
Sep 25, 2015 06:42 PM
