Breather
Old Nov 13, 2003 | 11:36 PM
gio_09_75's Avatar
gio_09_75
Default Breather
<FONT face="Verdana, Arial, Helvetica, sans-serif" size=2>What does a breather actually do, is it used for something or is it to show off. Can someone tell me the pros and cons for this if there are any.</FONT></P>
<FONT size=2></FONT></P>
<FONT size=2>Thanks</FONT></P>
</P><edited><editID>gio_09_75</editID><editDate>37938.9065509259</editDate></edited>
Old Nov 15, 2003 | 09:08 PM
89muscle's Avatar
89muscle
Default Breather
well i have one because i have different valvecovers and it doesnt have the pipe from it to the throttle body, to be honest i dont know why you have to have one but my motor guy told me i should.
Old Jan 27, 2004 | 07:14 PM
Ftr-Speedy's Avatar
Ftr-Speedy
Default Breather
the breathers or to let out the heat in an engine, engine produces heat=heat causes frictions, the breathers let the heat escape or disapate faster their fore less friction, as far as i know, they don't do alot, more like an accessory, but i guess if u have a high power engine and run it in drags or races, be a good idea.</P>
Old Jan 27, 2004 | 07:17 PM
Black Horse's Avatar
Black Horse
Default Breather
</P>
there not to let out heat...they are to let out pressure....if you didn't have a breather or a pcv valve, the blow-by from the rings will build up pressure in your crankcase causing you to blow out all the seals and gaskets</P>
Old Jan 28, 2004 | 12:31 AM
TheGmKiller331's Avatar
TheGmKiller331
I ♥ Acer
Default Breather
It also promotes piston ring sealing by letting those built up pressures out.I dont know where you got that info on the heat but it is wrong.
Old Jan 28, 2004 | 03:40 PM
vfast's Avatar
vfast
I ♥ Acer
Default Breather
gm..I don't use a pcv or breather in my s/c I just leave the tube hole open that would go to the T/B ..works great..
Old Jan 28, 2004 | 05:07 PM
TheGmKiller331
I ♥ Acer
Default Breather
Thats still a form of a breather.Anything that lets or draws that air out of the crank case will work.i run one filter breather on the drivers side,and another breather cap going to the carb.It works really nice.As long as its vented and not capped off you are ok.
Oct 26, 2015 05:01 PM
Ipaman
Sep 22, 2015 07:01 AM
Ilikeponys
Feb 8, 2006 01:52 PM
Dbeck002
Apr 23, 2005 08:48 PM
svtcobras.com
Jan 8, 2005 09:43 PM
