17'' to 18" wheel change question
Old Jul 27, 2009 | 09:00 PM
intemidater's Avatar
intemidater
Default 17'' to 18" wheel change question
have 17x9 factory wheels,i want to go with 18x10 on back and 18x9 on front. other than the fact of no rotation now ,do I need to change anything to keep my speedodometer accurate.
Old Jul 27, 2009 | 09:03 PM
DreamerGT's Avatar
DreamerGT
tires.....
Old Jul 27, 2009 | 10:03 PM
Monkeyleg's Avatar
Monkeyleg
Your speedometer won't change unless you go with tires that are taller than 27" (I'm assuming you're putting these on a 2005+ car).
Old Jul 29, 2009 | 08:15 PM
intemidater
no its a 04
Old Jul 29, 2009 | 08:35 PM
LilRoush's Avatar
LilRoush
Sizes varies slightly by brand.... but roughly a 265/35 on the 18x9 and a 295/35 on the 18x10 will work out for you. It's what I run on mine.
Old Aug 1, 2009 | 09:10 PM
Bman2000's Avatar
Bman2000
not to say your combo doesnt work, but i hated how the 265s looked on my car, next day traded them in for 275 35 on the front, looks much better, and 295 35 on the back no rubbing problems either!
Oh and to answer original question, my little gps unit actually put my car dead on accurate with the speedo with these tires on.
Old Aug 1, 2009 | 09:28 PM
DarkJFMan's Avatar
DarkJFMan
17 to 18 would definitely not cause any noticeable changes to your car.
Old Aug 1, 2009 | 11:07 PM
OnyxCobra's Avatar
OnyxCobra
like said as long as you get the correct size tires for the rear your speedo should be just fine. I also run 295/35 but you could also run 285/35 or 315/30 and you'll be good to go.
drfister
May 3, 2018 10:38 PM
Mr. D
Wheels & Tires
15
Aug 22, 2015 02:58 PM
WAstang2013
Wheels & Tires
Aug 12, 2015 08:19 PM
ccwebb
Aug 11, 2015 06:47 PM
mustangfan305
Aug 7, 2015 11:09 AM
