car does not start
Old Jul 6, 2005 | 11:27 PM
89fiddy's Avatar
89fiddy
Default car does not start
i have a 89 mustang and my car does not start when it is hot outside. It starts when it sits for a while and cools down. When it heats up and i turn it off and then go to start it back up it does not turn on. What can be wrong with it?
Old Jul 6, 2005 | 11:38 PM
dc_mann8's Avatar
dc_mann8
Default RE: car does not start
does it make a click? sounds like solenoid.
Old Jul 6, 2005 | 11:59 PM
99saleen351r's Avatar
99saleen351r
I'd bet its the ignition modual,They do that when they get hot
Old Jul 7, 2005 | 12:28 AM
cammedlx's Avatar
cammedlx
When a module goes bad its bad,Sounds like the pick up coil in the distributor.
Old Jul 7, 2005 | 04:29 AM
HAUS's Avatar
HAUS
i know this isnt good for your car but when its hard to start just pump the gas a little and see if it starts up. i had the same problem and it helped. when they did emmissions on my stang it fixed the problem. they had to fix a bunch of stuff for it to pass and it solved my hard starting.
Old Jul 7, 2005 | 03:37 PM
89fiddy's Avatar
89fiddy
It doesn't make a clicking sound. It cranks like it is about to turn on but it never does. Sometimes it kinda turns on and then shuts off. I have to open the hood and wait about 20 minutes for it to cool down then it starts up fine
Old Jul 7, 2005 | 03:38 PM
89fiddy's Avatar
89fiddy
I tried that and it does't work. I just have to wait a little bit for it to cool down. then it starts.
Old Jul 7, 2005 | 03:39 PM
89fiddy's Avatar
89fiddy
Would getting a new one fix the problem?
Old Jul 7, 2005 | 07:20 PM
88 347 stroker's Avatar
88 347 stroker
I had a similar problem and it was the starter, i got a new factory ford starter and put a $15 heat blanket on it and havent had a problem since. it did the exact same thing, but mine would crank real slow some times depending on how hot the engine was and sometimes it wouldent crank at all makeing the same noise as yours, it was really weard but it's fine now.
Old Jul 7, 2005 | 07:56 PM
89fiddy's Avatar
89fiddy
where can i get the heat blanket at?
