Need help with an engine swap! know anything please help
Old Aug 22, 2009 | 05:35 PM
bfleenor's Avatar
bfleenor
Default Need help with an engine swap! know anything please help
I am swapping out a stock 1993 mustang 2.3 engine with a big ford 351m engine with a c.6 transmission.
I really have no clue what i need to change or add or take out... if someone can please help or point me in the right direction i would greatly apprecaite it.
thanks
Ben
no clue at all really and i need the help please!!
Old Aug 22, 2009 | 07:48 PM
GreyStang's Avatar
GreyStang
Dude if you don't even know where to START,, then you're gonna have to have a garage do the swap,, for mega $$$'s
I can't imagine "talking you thru an engine swap" on a web forum
Have you pulled the old motor out already? That's the EASY part
Old Aug 22, 2009 | 08:31 PM
Solitear's Avatar
Solitear
NO buying the Crate motors the easy part you dont break sweat!!!!!!
Old Aug 22, 2009 | 09:32 PM
bfleenor's Avatar
bfleenor
Im gonna have the engine pulled in acouple days.
ill be able to put the motor in and everything ill have the other engine and put it in. its no problem. i have the motor mounts im just wondering waht im gonna have to replace.
lol just a list? maybe haha idk im sure i can get it started :-)
thanks for your guys replies and i woudl greatly appreicate the help
Old Aug 23, 2009 | 01:25 PM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
Your going to need a new engine wiring harness, new CPU (unless your giong with a distributor), a new K member, new rear end, new fuel supply set up, bigger breaks (much bigger breaks!). new shocks/struts....thats just a few things that are going to cost you a bit....someone else can help me out with pther misc things you need.
Matthew
Old Aug 23, 2009 | 01:30 PM
bfleenor's Avatar
bfleenor
its a carborated engine. so he said im not gonna need a cpu
Old Aug 23, 2009 | 01:33 PM
Matt's 95 Stang
Resident Ginger
^^That is true, you wont need a CPU.
Matthew
Old Aug 23, 2009 | 01:39 PM
bfleenor's Avatar
bfleenor
im confused about the exhaust system.. do i get it for the mustang or for the headers of the 351?
Old Aug 23, 2009 | 05:25 PM
mudvayne1's Avatar
mudvayne1
If you are asking this question you do not need to be doing a engine swap. Have someone help you.
Old Aug 23, 2009 | 05:29 PM
a_penquin's Avatar
a_penquin
I'll sum the list up, you need EVERYTHING! mounts, exhaust, fuel, cooling, suspension, a rear that will hold up, maybe even a hood. I hate re-wiring engine swaps >.<
