Rear window replacement in 1988 Mustang
Old Aug 31, 2009 | 09:01 AM
Jakal's Avatar
Jakal
Default Rear window replacement in 1988 Mustang
Hi, this is my first post. I have a 1988 Ford Mustang with a convertible top. It use to have a glass rear window, but someone decided to break it, and climb in the car that way. I am in the middle of replacing it with a plastic rear window, but I am having some issues. The sides of the glass are not "tight" with the convertible top. Also, the corner bolts of the bottom bar that the window attaches to are missing. Can I even replace a glass window with a plastic one? Thanks.
Old Aug 31, 2009 | 02:00 PM
1ATony's Avatar
1ATony
Former Sponsor
Are you putting a zip in window back into it? You should be able to replace it with a plastic window. The only thing you might have an issue with is the zipper not lining up.
You might have to have a trim shop sew the other half of the new windows zipper in so that you can zip it.
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
inyadreems
Aug 21, 2015 09:10 AM
daytooday
Aug 11, 2015 09:22 AM
Mustang Sally72
Aug 11, 2015 07:54 AM
