2003 Mach 1 ABS
Old Sep 9, 2009 | 07:35 PM
n269mach1's Avatar
n269mach1
Default 2003 Mach 1 ABS
I have a 2003 Mach 1, and the ABS Light comes on and the traction control does not work, I noticed that the rear brakes are not working either, anyone have any ideas what could be wrong, could it be the ABS Module or the ABS Hydrolic Plate or both, or could it be something totally different, also what years and makes of Mustangs will interchange. Thanks
Old Sep 9, 2009 | 11:52 PM
Jfsram's Avatar
Jfsram
How do you know the rear brakes are not working?
As for ABS issues. I usually look around for obvious problems. Cut wires, sensors filled with metal particles, cracks in the notched wheels (they are hard to see), burnt abs fuse. If all that passes. You need to have the diagnostic codes read.
Old Sep 10, 2009 | 06:20 AM
n269mach1's Avatar
n269mach1
Thanks, I have noticed rust on the rear rotors while the fronts after driving it they will be shining., also jacked the rear up and hit the brakes and nothing, which sensors and where are they located, Thanks again
Old Sep 10, 2009 | 11:37 AM
GreyStang's Avatar
GreyStang
You're rear brakes are SHOT.. get them fixed or fix them yourself. Doing too many standing/brake burnouts with the car?
Even if the ABS sensor wire was cut your brakes would still work.
Old Sep 10, 2009 | 01:15 PM
n269mach1's Avatar
n269mach1
LOL, this started after we hit a pothole or should I saw a ditch in the road
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
ChampInSD
Oct 2, 2015 04:55 AM
junior04
Sep 28, 2015 10:53 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
