car wont start
Old Jul 12, 2005 | 05:44 PM
AtlanticBlue99's Avatar
AtlanticBlue99
I ♥ Acer
Default RE: car wont start
yes but the car will start and run until the battery dies and without the alternator you will not beable to rechasrge while running down road. so you can run a battery dead and replace it everytime or have an alt. the alternator is not the problem here. like as stated above: check all electrical connections and spark plugs/wires
Old Jul 12, 2005 | 05:49 PM
99saleen351r's Avatar
99saleen351r
Sometimes people should just not respond!. Is the starter in a dead spot did you try to whack the starter with a hammer while someone is holding the key forward??Did you try to jump the starter solenoid with a screwdriver?And what would the spark plugs and wires have to do with anything???????????????????He said it just clicks when he turns the key ,Its either the starter solenoid or the starter Period.
Old Jul 12, 2005 | 06:07 PM
lift350's Avatar
lift350
i ran a jumper wire from the starter solenoid to the battery and it just clicked. so one would assume the starter is bad but it is not. i took it to autozone they checked it and worked fine. i got home and ran jumper cables to the starter while it was out of the car, ran a jumper wire to the starter and it worked fine. i put the starter back in the car and it will not work. so when i get home i am going to check the wire that goes from the battery to starter and i am going to check all grounds and see if this works. any other suggestions?
Old Jul 12, 2005 | 06:17 PM
99saleen351r
Put a screwdriver between the two post on the starter solenoid and I bet it starts.It will spark when you do it though so be ready.Oviosly while someone holds the clutch in so the nuetral safety swith is activated it could also be that switch
Old Jul 12, 2005 | 06:20 PM
99saleen351r
Try also jumping out the safety switch on the top of the cluch peddle assembly and see if that works
Old Jul 12, 2005 | 06:41 PM
ATV1LI's Avatar
ATV1LI
See if you can borrow a load tester to ck bat, that would give you a better indication then a voltage reading alone. Did you try jump starting ?You can disconect the bat & jump right at the starter, just make sure to ground the neg cable.
Old Jul 12, 2005 | 06:46 PM
lift350's Avatar
lift350
jump starting it was the first thing i tried and it did not work. i will try the stuff that was posted on here when i get home and see if it works. thanks for all your help and cross your fingers
Old Jul 13, 2005 | 12:28 PM
babygurl2000's Avatar
babygurl2000
I ♥ Acer
whynot take the starter apart and clean the brushes? OMFG..
you are so right that some ppl should not respond..........* rolls eyes*
Old Jul 13, 2005 | 01:30 PM
lift350's Avatar
lift350
problem solved, somehow the ground wire that goes from the battery to the engine broke. put a new end on it bolted it back to the engine and started right up. thanks for everybodys help
Old Jul 13, 2005 | 01:46 PM
99saleen351r
ORIGINAL: babygurl2000
Are you serious???You can take it apart if you like.... whatever!@!!!!You know so much more than I or atleast pretend to.Youve never heard of whacking the starter to get it off the dead spot????I forgot more about stangs than you'll ever know.My girl rolls her eyes at me It doesnt get her anywere thou,Ive been working on cars and trucks(macks and petes) for 15 years and have a lift at my house .I dont answer cause I can I answer cause I know.If you dont know you should just refrain from talkin.
