car wont start
Old Jul 11, 2005 | 03:23 PM
lift350's Avatar
lift350
Default car wont start
95 gt 5 speed, just does a single click, battery has 12.3 volts and when i try to start it drops to 11.2 volts, so it is not the battery. pulled the starter out and had it tested, works fine when it is out of the car. put it back in still will not work. ran a jumper from the starter to the battery and just clicks. could this be a bad ground? or what else should i check?
Old Jul 11, 2005 | 03:33 PM
babygurl2000's Avatar
babygurl2000
I ♥ Acer
Default RE: car wont start
i would check your cables and connections. i had the same problem in the Beretta. the ground came lose is all it was.
good luck.
Old Jul 11, 2005 | 03:42 PM
lift350's Avatar
lift350
i forgot to mention that i put new battery terminals on, thinking that might be the problem but it still will not start.
Old Jul 11, 2005 | 05:04 PM
99saleen351r's Avatar
99saleen351r
Is the motor free or maybe its locked up?
Old Jul 11, 2005 | 06:57 PM
Scooterman's Avatar
Scooterman
alternator going?
Old Jul 12, 2005 | 03:32 PM
lift350's Avatar
lift350
the engine is not locked up.
how do i check the alternator if it does not start? and how would the alternator keep it from starting?
Old Jul 12, 2005 | 05:20 PM
babygurl2000
I ♥ Acer
your alternator recharges your battery. hence if the alternator is bad then its not keeping your battery at its full potential
Old Jul 12, 2005 | 05:28 PM
P Zero's Avatar
P Zero
the alternator doesnt have a damn thing to do with it. If the battery is fully charged the alternator doesnt even have to be in the car in order for it to start. Clean all the connection including the soleniod these are teh most important connections. make sure theyre all tight and it should work. if it doesnt just get a new starter theyre relatively cheap. Make sure the battery is fully charged though, then do all of your tests.
Old Jul 12, 2005 | 05:38 PM
babygurl2000
I ♥ Acer
ok wtf is the alternator for then?
dont patronize me b/c i happen to know for a fact that the alternator recharges the battery.
you need to get educated
Old Jul 12, 2005 | 05:42 PM
babygurl2000
I ♥ Acer
the main function of the alternator is to convert power from the gasoline engine that drives you along the road, to electrical energy to keep the battery in tip-top condition.
