Sponsored by:
Sponsored by: DashLynx
need help 07gt v8 cat converter removed
Old 10-01-2009, 09:33 AM
biljeek
biljeek's Avatar
Default need help 07gt v8 cat converter removed
hi all
cat removed with mid x pipe and magnaflow catback
i am facing a slight problem after i removed my cat converter, the issue is every time i push the clutch while stopping or down shifting the RPM goes under 5 for 2 seconds then goes to idle and some time this cause turn the engine off, this also happening when i rev the car while stopping.
do i need to tune my car with SCT tuner? is the tuner gonna solve my issue?
biljeek is offline
Old 10-01-2009, 10:24 AM
2011Black5.0
2011Black5.0's Avatar
well im running catless and i have a tune so i would guess that if the problem started after the cats were removed then you might wanna have it tuned or if it has a CEL or the service engine soon light on, get the SCT and it has a code reader that should tell you the problem
my car gives me a CEL for "catalyst efficientcy below thresh hold" or something like that so i just use my SCT when ever it comes up and clear the DTC
2011Black5.0 is offline
steelcomp
09-09-2012 01:15 PM
joutcelt
09-11-2009 09:33 AM
06stangGT
08-31-2009 01:03 AM
rojizostang
07-30-2008 12:04 PM
czito
07-24-2007 02:10 PM
Quick Reply: need help 07gt v8 cat converter removed
