Passenger side door problem
Old Oct 15, 2009 | 10:40 AM
Sparksone42's Avatar
Sparksone42
Angry Passenger side door problem
Hello,
I have a 2000 Mustang 3.8 and I am having a problem with the passenger side door. The electric lock no longer works (using either the keyless remote or the buttons on the door itself) and the dome light will not come on when the passenger door is opened.
The dome light does work with the headlight switch and the driver's side door. Previously, I had a problem with the passenger door where after opening the door the dome light would not go out. This happened whenever it rained for a period of time so I suspect water is getting to the jamb switch.
My problem is that I can't locate the jamb switch In all of my other vehicles they are easy to spot as they are a plunger type switch however, I can't see anything like that on the stang.
Can anyone provide some information as to where these buggers are?????
Thanks for your help.
Old Oct 16, 2009 | 04:55 PM
95 GTS's Avatar
95 GTS
I think the switch is part of the door latch now.
Old Oct 17, 2009 | 02:53 PM
hiboostwoody's Avatar
hiboostwoody
Yep, the switch is part of the door latch now. This is a common problem. The latch get gummed up with dirt and crud. Usually a thorough soaking of the switch with some penetrating oil like WD-40 will take care of it.
Old Oct 19, 2009 | 09:19 AM
Sparksone42
Thanks guys, I'll try that and see if it works.
Bullet 67
Sep 18, 2015 08:00 AM
mtxplod
Aug 29, 2015 01:43 AM
inyadreems
Aug 21, 2015 09:10 AM
kirk35
Aug 17, 2015 08:42 PM
daytooday
Aug 11, 2015 09:22 AM
