Much to learn:Shaker whats it do?
No, because the airmass intake is done through the shaker part of the hood, which is then funneled directly into the intake.
A cold air intake goes from the intake and down into the wheel well (to draw in cold air, hence the name). A shaker hood draws air in from above the hood, which is already at ambient temperature (and thus as "cold" as it's going to get).
Basically, even if you could use a CAI kit and a shaker hood together (which you can't), you wouldn't want to be cause a shaker intake does everything a CAI can do, but better.
until I decided I wanted the look and performance, then did this
I guess I should have been more specific.
When I said "you couldn't do it," what I really meant was "you couldn't do it and have them both be functional."
I mean, if someone asked me if they could use a carburetor on their EFI mustang, I would say that you couldn't do it because their purposes are in direct conflict. HOWEVER, that isn't 100% correct because you could, in theory, just spot-weld a carb to your engine block and then technically you would have both at the same time. However, when someone was asking if they could use a carb and EFI at the same time, I think we could be pretty sure that's not what they meant.
Given the OP's question, I figured he meant to ask if there would be any reason to have both a shaker and a CAI kit. I was trying to show him that other than looks, there is no real benefit to having both at the same time.
Toy4Bob, I'm not completely sure how the airflow works on a Mach shaker hood assembly, but in your first photo, isn't that aluminum tube extention into the side airbox allowing UNFILTERED AIR into the engine?? ouch
A carburetor can actually be used as a throttle body if it modified correctly. i understood what you meant though. Both times.
In set ups like these, bolt on sharker/scoops are a joke if you are talking 'performance'.
And for the record, I agree with Fobra on this (yeah, I know, I said it). You aren't pushing air in like one might think.
Nope. The 'shaker' is running air into that tube... which is feeding the filter, leading into the motor. It's a lot of twists and turns (aka flow restrictions) to make it happen.
