CHECK ENGINE CODE ERROR
Scanners from auto parts stores are crap. It's a Ford so take it to a Ford dealer. They will put an NGS on it and find the problem fast. FYI though, when a diag tool cant communicate with the PCM, its may mean that the PCM is toast.
Yep, sometimes a code can have an error or be undefined with cheaper models. I would have a Ford dealer scan it like previously mentioned, hopefully it isn't toast though. Also, any exhaust mods? And when was the last tune up? Can you tell if anything is happening under acceleration, does it feel different?
I replaced the rotor,cap,and plugs ,fired it up and it had a rough idle.Took around the block and it cleared up,but when I got back,I let run at idle and it was smooth for about 3min,then rough idle and check engine light.Any suggestions?
Not true. There are cars that have (16 pin) connectors OBD2 but have (12 pin) connector OBD1 hook ups/systems. (4 of the pins are blank) An OBD2 plug will fit an OBD1 connector and vice versa.
