EGR Delete Kit worth it?
Old Nov 19, 2009 | 09:57 PM
Stang9946's Avatar
Stang9946
Default EGR Delete Kit worth it?
So I was looking at this EGR delete kit for $15:
http://www.modulardepot.com/Exhaust/...duct_info.html
Is it worth buying?
What are the benefits of deleting the EGR?
Disadvantages?
Will it harm or hurt anything?
Are there any other parts I will need to buy if there are any disadvantages to this?
Old Dec 4, 2009 | 08:00 PM
Stang9946's Avatar
Stang9946
Nobody?
Old Dec 5, 2009 | 10:14 AM
dreamer1uk's Avatar
dreamer1uk
Hi,
If you disable the EGR, you will be increasing the amount of emissions coming from the exhaust (particulary NOx) as well as probably throwing a check engine light. The purpose of the EGR is to recirculate exhaust gases back into the combustion chamber.
Contrary to belief, the inert gasses that are placed back into the combustion chamber help reduce the heat build up in the cylinder. Removal or an EGR valve stuck closed will cause a lean condition, which will be seen via STFT values on a good scan tool.
You will have to see if the other members have disabled there EGR and see how there vehicles are running.
Hope this helps.
2007CalSpec
Dec 13, 2020 11:42 AM
BrantleyS550
Sep 14, 2015 04:18 PM
TfcCDR
Sep 14, 2015 12:08 PM
Camster
Sep 10, 2015 11:18 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
