low brake oil
Old Jul 19, 2005 | 03:29 AM
Scooterman's Avatar
Scooterman
Default low brake oil
i realized as i was putting my exhaust in that my brake oil is below the line... my friend says that could be the reason why i grind sometimes shifting, any1 second that or is it not true?
Old Jul 19, 2005 | 05:18 AM
Kendawg's Avatar
Kendawg
Default RE: low brake oil
Well, i'm assuming by brake oil you mean Dot3 brake fluid? If that is below the line, then I am assuming you have never been to a jiffy lube or other service station that tops off your brake fluid... unless you have done it yourself. It means your brake pads are getting low, when you compress the pistons it will go back up.
If you meant the brake fluid for you clutch... then yea, that could cause you to grind gears... must have a leak.
Old Jul 19, 2005 | 02:21 PM
99saleen351r's Avatar
99saleen351r
So your brake fluid being low causes you to grind gears?????Wow thats a first!You dont have a hyraulic clutch setup do you?If you dont which I dont think you do then this has NOTHING to do with grinding
Old Jul 19, 2005 | 09:32 PM
DaGGer's Avatar
DaGGer
if you do have a hydrolic clutch then this is plasible. The fluid being low could cause the clutch to not totaly disingadge. I know my father 1996 ford ranger has a hydrolic clutch.
Old Jul 20, 2005 | 03:33 AM
2001 GT's Avatar
2001 GT
Just go to any auto store and top it off too the fill line regardless. Just don't spill it on anything!!
Old Jul 20, 2005 | 06:11 PM
mike02's Avatar
mike02
go to auto store buy dot 3 brake fluid, put in master cylinder resevoir. brake fluid being low does not cause you to grind while shifting. low clutch fluid does. also use dot 3 brake fluid.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
musnicki
Sep 23, 2015 07:11 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
DoctorScary
Sep 9, 2015 07:53 AM
Sep 8, 2015 11:50 AM
