90 5.0 starting problem
Old Jan 16, 2010 | 05:00 PM
omar_lpz's Avatar
omar_lpz
Default 90 5.0 starting problem
k so i have my batery disconected because my starter is stuck i think ,wen i connect the batery it trys to start on its own without the key in the ignition and i just seen that the batery post started melting .any one know wat i can do to fix this ?
Old Jan 17, 2010 | 10:14 PM
MustangBradley's Avatar
MustangBradley
Your solenoid is stuck in the closed position. This can be because the relay has failed and sticks, or the solenoid on the starter has failed. Locate the starter relay in the underhood power distribution box and remove it. Touch the battery cable to the post. Does the starter turn? If not, you can just buy a new relay. If it turns, get a new starter.
Old Jan 17, 2010 | 10:23 PM
Jfsram's Avatar
Jfsram
I'd go with your first guess. The solenoid is stuck closed. Most likely but there is a chance it's constantly energized with a 12 v input from the ingnition key switch. Unplugging one of the 2 small wires on the starter solenoid would confirm.
The starter relay/power distribution box? None of these high tech stuff on the foxes.
Old Jan 17, 2010 | 10:33 PM
MustangBradley
I just realized that the 1990 did not have the underhood powerbox. I think that came in with the 1994. So you don't have a separate relay from the one on the starter. Sorry about that.
Old Jan 19, 2010 | 01:36 PM
omar_lpz's Avatar
omar_lpz
alright thanxs it worked
Cannibal_carnies
Mar 2, 2023 06:17 PM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
jjwinel78
Aug 17, 2015 03:34 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
Pain.
Aug 7, 2015 10:48 PM
