Driver's door does not unlock with keyfob
Old Jan 19, 2010 | 07:51 PM
FordGT2006's Avatar
FordGT2006
Default Driver's door does not unlock with keyfob
I just bought a 2006 GT- everything seems to work fine except I can't unlock the drivers door with the keyfob. I can unlock the passenger door with it. I can lock both doors with it. I can activate the anti theft with it. I can only unlock the driver's door with the key. I reprogrammed the keyfobs, seems to follow the manual. Keyfob works for trunk properly. Any thoughts to fix before I call the dealer?
Thanks, Ron
Old Jan 19, 2010 | 08:25 PM
chronos's Avatar
chronos
Take it back, let them mess with it. You should have some warranty.
Old Jan 19, 2010 | 09:13 PM
FordGT2006's Avatar
FordGT2006
That's probably what I am going to end up doing- I've been checking the forums and can't find a common answer. I am always up for a technical challenge. Would prefer to fix myself instead of going back to the dealer. They have a tendency to cause more problems.
Old Jan 19, 2010 | 09:18 PM
elmo3000's Avatar
elmo3000
Have you tried hitting the unlock button twice? I have to do that with mine! Let me know how it goes!
Elmo
Old Mar 22, 2010 | 09:50 PM
ga chopper's Avatar
ga chopper
reset it.... turn key on then off 8 times the locks will cylcle and hit lock on the fob (if u have more do them at the same time)
Old Mar 22, 2010 | 09:51 PM
ga chopper's Avatar
ga chopper
it could just be a bad fob if that does'nt fix her
Old Mar 24, 2010 | 01:38 AM
hiboostwoody's Avatar
hiboostwoody
Does it unlock with the button in the door itself? If not you may have a bad door lock actuator.
jerrytubes
Oct 23, 2015 12:11 PM
TCStangerv6
Oct 11, 2015 05:57 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
