timing retard/advance
Old Jul 25, 2005 | 11:46 PM
9646gt's Avatar
9646gt
Default timing retard/advance
Can someone tell me when to use these two options. I know using superchargers and nitrous is a factor in determining timing, is there anything else. Also, just for clarification, what exactly does timing retard and advance mean? I know that advance moves it forward and retard moves it back, but back from what? does the plug fire at TDC all the time? also, in what increments do you move up in?
Old Jul 26, 2005 | 02:18 PM
fordguy17's Avatar
fordguy17
Default RE: timing retard/advance
you move timing in degrees. for your 4.6 you would have to get a timing adjuster.
you can advance the timing to give you more power. most of the time you will need to run a higher octane to keep it from detonating or pinging.
Old Jul 26, 2005 | 03:32 PM
MikeHawke's Avatar
MikeHawke
Retired MF Moderator
ORIGINAL: 9646gt
1) The plugs fire just before TDC.
2) You are advancing or retarding based on the factory setting which is something like 14 degrees (correct me if I'm wrong, please)
3) higher compression ratio engines and those with forced induction (superchargers and turbos), require less timing than a low compression, naturally aspirated engine.
mungodrums
Oct 7, 2015 04:01 AM
clowe1965
Carolina Regional Chapter
34
Sep 28, 2015 09:18 PM
StalkerGT
Sep 25, 2015 02:41 PM
Sep 8, 2015 11:50 AM
