RWD How To?
Old Feb 28, 2010 | 12:12 PM
TheMustang000's Avatar
TheMustang000
Default RWD How To?
Hi all I wnat to get a Mustang but the one thing that makes me worry is driving a RWD in the snow/ice and skiddings occuring.
What is the corret way to control a Mustang in a skid.. I heard you should never slam the breaks. I know for FWD you ease into the break and steer the opposite direction to realign.
For a RWD I heard you do the opposite and actually accerate a little bit, then do you ease into the break, and also guessing you steer the way you are going?
Please help convince me, cause I am confused about RWD never driving one
Old Feb 28, 2010 | 12:49 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
first move some where that doesnt have snow...second buy a mustang
Old Feb 28, 2010 | 02:12 PM
dastangman's Avatar
dastangman
its not that hard...i dont drive my mustang in the winter but thats not for that reason, id rather not get the wet salty sandy **** on it...anyways, just drive slow and steady, its not that different, if ur rearend kicks out kick in the clutch to snap it back in place. if it goes to spin just turn your wheels in the direction you want the car to go. just take it to an abandoned parking lot and drift it on the snow and youll get an idea. a mustang is just like a rwd truck or any other rwd car.
Old Feb 28, 2010 | 02:18 PM
dastangman's Avatar
dastangman
accelerating would be counter productive as that would only fuel you to spin farther, but it is true you can control the drift with the gas, but not smart in that scenario where you have no traction...i couldnt get the edit post button to work
Old Feb 28, 2010 | 06:08 PM
67mustang302's Avatar
67mustang302
The easiest way in ANY car is to ease completely off the throttle and let the car straighten itself back out. Turning into the skid can help, but if you hook back up it can lead to an over correcting situation. Generally you want to just ease out of the throttle though, and if the car doesn't recover then you were driving too fast for the conditions and/or have the wrong tires.
The correct tires and driving lessons go a long way. If you can find a place that does skidcar training that'd be the best, since they'll teach you how to actually control a car in a skid.
Old Mar 2, 2010 | 12:13 AM
Shotgun Love's Avatar
Shotgun Love
i drive mine in the snow- its actually a lot of fun. if you skid, just turn into the skid and give it a little gas. A little practice in a parking lot will go a long way
Old Mar 3, 2010 | 03:42 AM
Unsullied_Spy's Avatar
Unsullied_Spy
I never drive mine in the snow because of the crap they use to melt the snow, even in MT where we don't use salt there is still sand on the road for traction and I won't risk my paint like that. The best advice I can give you for driving anything on snow/ice is don't make any quick movements on the wheel and never jab the throttle or brakes. If you feel the car getting unstable, you're going way too fast and need to slow down. If the rear end gets loose just put in the clutch and it should straighten itself out, counter-steering isn't always required. Just be smooth, smart, get good tires, and get some weight over the rear tires for traction and you should be fine. It helps to go out to a snowy parking lot when nobody is around and just practice driving, my Dad taught me how to drive but I learned to DRIVE in an icy parking lot.
Old Mar 3, 2010 | 04:51 AM
brandonse24's Avatar
brandonse24
snows not to bad, here in the mountians of wv i drive mine daily in all weather and can honestly say i have never lost control of my car in bad weather. as long as your careful its fine but when im out having fun and break loose i just let off the gas and she comes right back.
Old Mar 4, 2010 | 08:57 PM
Jfsram's Avatar
Jfsram
There is no way I could write out a driving on snow lesson here but your throttle technique is backwards.
Front or rear drive. Avoid braking during a skid. In a rear drive, release the throttle. It will give your rear wheels traction and help the car stop sliding sideways.
For front drive, throttle will actually help pull the car straight.
Either front or rear, always steer in the direction you are trying to go.
I have a 93 with 4 very aggressive soft compound snow/ice tires. It stops, steers and accelerates about 900 time better than with it's summer performance tires when in the snow.
Seems to me you are concerned with losing control while at speed with your Mustang. I carpool with a guy who also has a Mustang. It's a 94 V6 but he only has snow tires on the back. It's limited on steering and braking but it's stable as a Dart on the highway.
It may seem backwards from common knowledge but snows only on the back of a front wheel drive also makes for killer stability in snow or ice.
PearlGenPu
Aug 12, 2015 01:57 PM
analog_boy
Jan 31, 2005 10:11 PM
2001_SaleenS281_08
Mustang Videos
29
Dec 21, 2004 03:48 PM
