Pressure washing
Old Jul 28, 2005 | 09:08 PM
F1rocco's Avatar
F1rocco
Default Pressure washing
Tried it out today for 15 minutes no brushing required..........
Before
After
Pressure washer cost $90 Used a degreaser
Old Jul 28, 2005 | 10:40 PM
DaGGer's Avatar
DaGGer
Default RE: Pressure washing
what do you have to cover when you pressure wash the engine, also should you have the engine on or off.
Old Jul 29, 2005 | 02:17 AM
02StanGT's Avatar
02StanGT
I would recommend cover any wire connections that might get wet. Nothing like misfiring when your plug wires get wet. Also I recommend running your engine til it gets to normal operating temp, shut it off, then wash it. Dirt and grease will come off easier.
Old Jul 29, 2005 | 02:40 AM
P.S.I.cho's Avatar
P.S.I.cho
some say to run it some say not to, personally if i ever wash my motor i think ill keep it running sometimes after u spray water on the warm motor it wont turn over for a little while u have to let the water dry
Old Jul 29, 2005 | 04:18 AM
babygurl2000's Avatar
babygurl2000
I ♥ Acer
umm did you put simple green on there before you power washed it? I left my car running when i did mine and it made a really big difference too.
looked like a brand new motor when I got done.
Old Jul 29, 2005 | 10:50 AM
03GTType's Avatar
03GTType
Thats what I used too.. Simple green does wonders for engines..
Old Jul 29, 2005 | 11:07 AM
F1rocco's Avatar
F1rocco
ORIGINAL: babygurl2000
I actually used a product called Cindet...Its a low sud degreaser wax stripper soap with warm water....I ran my car while I did it..I am always worried about the water on the hot block while running though...
Old Jul 29, 2005 | 02:01 PM
DaGGer's Avatar
DaGGer
ok so people have run it and its fine, i have hear that a hot block will absorb the soap and screw **** up, but i guess that hole bunch of wires on the right hand side of the engine get covered up anything else
Old Jul 29, 2005 | 02:04 PM
UhadMEatGT's Avatar
UhadMEatGT
Thats the cleanest rust ever
Old Jul 29, 2005 | 02:26 PM
99saleen351r's Avatar
99saleen351r
Ya that is some shiny rustYou should have the motor running when cleaning and dont worry about covering anything everything is able to get wet without problems.After I wash mine I spray all the black with foaming tire shine and it looks awesome you should try it
