Gears?
Old Jul 12, 2010 | 07:38 PM
TR!$T@N.'s Avatar
TR!$T@N.
Default Gears?
can someobdy explain how aftemarket gears help your car? i see it alot on here but i dont understand how it works.
Old Jul 12, 2010 | 09:43 PM
67mustang302's Avatar
67mustang302
Power from the engine is multiplied by the transmission(or reduced when in overdrive), then multiplied again in the differential. Changing the gears in the diff changes the power multiplication, but also changes the available range of speed in each gear. A numerically higher gear puts more power down to the wheels giving faster acceleration, but at the cost of reduced max mph in each gear.
To give you an idea, assume some arbitrary engine producing an arbitrary amount of power. It goes through an arbitrary transmission and out pops X amount of power. With stock 3.27 gears you have X times 3.27, but with 4.10 gears you have X times 4.10. The total between the 4.10 divided by 3.27 is around 1.25....as a percentage that means the 4.10 gears increase power at the wheels by approximately 25% over stock 3.27 gears.
Ideally for drag racing you want to pick the most gear that gives you the most acceleration and has you trapping at the top of a certain gear, 3rd or 4th usually.
Old Jul 12, 2010 | 11:38 PM
bigjohnstud4200's Avatar
bigjohnstud4200
WOW, mouthful. Nice info. i tend to think of it like a 10 speed bike.
If you put it in a high gear you can crank the hell out of it and get moving fast quickly but you run out of gas a lot faster. If you put it in the low gear, the start is tough but once going you're have a whole lot more top end.
Not sure if that's accurate but it gets me through the day.. I have a set of Ford 3.73 sitting in my spare bedroom waiting for an install day. Can't wait!
Old Jul 13, 2010 | 03:57 PM
TR!$T@N.'s Avatar
TR!$T@N.
so if im just driving on the street i would buy 3.73 gears instead of 4.10
Old Jul 13, 2010 | 06:24 PM
GreyStang's Avatar
GreyStang
You're not giving us enough info, what do you want from your car?
Oh wait,, you don't even have a car?? What do U want gears for? Maybe you're just wanting to learn about cars?
Old Jul 14, 2010 | 10:34 AM
Franchi's Avatar
Franchi
Depends on application, what you want out of it, does gas mileage matter much, ect ect.
Personally I run 4.10 gears and the car winds up LOT quicker then it did prior. But you also spend a lot more time shifting, gas mpg dropped some, ect ect
There's pros and cons to all of it.
Old Jul 14, 2010 | 01:06 PM
67mustang302
What kind of racing and engine setup you have determines to a great extent the gear selection. 4.10 is good for drag racing, but some of the guys with turbo or positive displacement blowers prefer smaller gearing like 3.27-3.55 for traction. I prefer road racing/autox type stuff so I don't go higher than 3.55 since you're better off with more mph range in each gear and need the top speed of 130-140+ for fast tracks.
It all depends.
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
