Bleeding the Power Steering Ram
Old Aug 11, 2010 | 06:41 PM
tigers67stang390's Avatar
tigers67stang390
Default Bleeding the Power Steering Ram
I'm replacing a power steering ram cylinder on a 67 Mustang, and I believe that there is air in the lines. With the pump full of fluid, I turn the car on, touch the steering wheel and the wheel quickly spins back and forth. I try bleeding the lines to the cylinder, but I cant stop the steering wheel from spinning. Any suggestions on what is causing this & how to fix it?
Old Aug 11, 2010 | 10:27 PM
Jfsram's Avatar
Jfsram
The only way to bleed the system is to be patient.
When the fluid sits in the power steering resorvoir. The air bubbles will rise to the surface. The next time the engine is running. Bubbly fluid from in the ram will eventually go to the resorvoir. Again, time for the air to rise to the surface, eventually it will be all gone.
Old Aug 12, 2010 | 04:24 PM
tigers67stang390
what would cause the steering wheel to spin quickly back & forth by itself? if it had air in the lines, wouldn't that just make it tough to turn the wheel?
Old Aug 12, 2010 | 09:48 PM
88Mach1's Avatar
88Mach1
sounds to me like you have the hoses backwards. i had 'em mixed up on my '69, and if i just barely touched the steering wheel, it would rip outta my hand and go all crazy.
Old Aug 15, 2010 | 05:51 PM
tigers67stang390
Yep, that was it. The lines are crossing, but that was the fix. Thanks.
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
ChampInSD
Oct 2, 2015 04:55 AM
Sep 25, 2015 06:58 PM
